thenillaz »
https://forums.nicoclub.com/thenillaz-u54851.html
Wed Mar 28, 2007 12:27 pm
Thinking about it logically, and this is what I've also been told, if you get a bigger over all wheel(tire+rim) you're going to have more legnth of tire in a single revolution of the wheel to cover than a smaller wheel. So if you think about it, the load being put on the engine to rotate the transmission to get that single revolution of the wheel is great than a smaller wheel, thus your car will slower. Thiking about it had me second guessing while I wrote this, but keep in mind only the overall length of the tire is changing, not the axel or driveshaft or gears. So maybe I should reword it as a single revolution of the drive axel. Even though a single revolution will get you farther with a bigger tire, the amount of resistance against the engine, because of the increase in friction of the bigger tire, slows down the rate your accelerate.
So in conclusion, a bigger wheel will make the car slower. Don't be alarmed though, the difference is probably completely unoticable. Besides its only an 17in rim, most people here do it and its nothing out of the norm. Keep in mind what people are saying as far as the profile of the tire and conering, because this is only the acceleration aspect.
