Dad Drift »
https://forums.nicoclub.com/dad-drift-u279796.html
Tue Jan 02, 2018 10:58 am
hello I am new here I posted this on another forum few days ago with no replies so hopefully I get some replies here
sr20 notchtop stock besides exhaust, fmic.
I'm not sure whats going on with my sr20det. Ever since I got it over 4 years ago its had low vacuum about 14-15 inhg its not the gauge I tried 3 different ones. So about a year ago I started to look into it I did a compression test I got around 120 all across. This was done on a cold block without opening the throttle which I didn't read the fsm than and didn't know. I also did a boost leak test had no leaks but I did hear air hissing out of pvc and dip stick tube. I had no clue what that meant at the time until few days ago I read an article that said if air is hissing out of dip stick and pvc than piston rings are worn or cylinder walls. So right after I read that I went and got a cylinder leak down tester and it was %20 all across which is ok right? Now im like WTF is going on is the sr good or needs rebuild? I am currently gathering parts to go more boost gtx2867 but it would be pointless to throw more boost at a worn engine any sr20 experts here know if this engine is ok.
