does my maxima have a trunk release?
sal911ghost
Car: maxima,stanza
i just obtained a 1992 nissand maxima,it might sound like a stupid question but i cant find it (the key wont open it) plz help
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It's either a square button next to the interior light on the driver door panel, or the same lever that opens the fuel door, depending on the manufacture date. If it's the lever, pushing down opens one, pulling up opens the other (should be illustrated, mine isn't this way so I'm not sure which is which).
My key doesn't work in my trunk anymore, either. I think they must have used cheap tumblers for the trunk: all my keys work in the doors and ignition but not the trunk.
If your car is a GXE, you can also open the trunk by putting in your unlock code, then pressing 1/2 (says "TRK" above the button).
Also, just to forewarn you: DO NOT allow the small lever/switch on the trunk lid latch to be switched. This will DISABLE the electronic trunk actuator (intended for use when leaving your car with a valet or the like). If your key doesn't work and you disable the electronic opener, you'll be locked out of the trunk (though you can get in by removing the rear seatback at which point you might be able to manually release the latch with some effort).I'm not sure if this applies to the older (shared-lever instead of button) trunk release setups or not.
D-Maxima
Car: HSV VQ Statesman 5000i
my keys dont work either. i thought i was the only one!
for the keypad, I dont know the code but I got the tag and the metal tag as well. If i go to a nissan service dept can they sort it out for me?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yeah, just take in the metal tag and a dealer can use it to look up the original code for your car.
Make sure you have the right tag, though. There will be two: one for the master key reference (you can always get a fresh, clean new key cut this way, even if your own original is worn) and the other is for the keypad. One is longer than the other. I don't recall which is which.
