Well, I think USDM and JDM transmissions have same speed sensors. Only cluster displays KMH or MPH. Just like you can switch back and forth in USDM digital cluster. Sensor difference is only between the chassis s13 and s14.crccustoms wrote:your fuel level, headlight indicators will all work, i believe the only issues come with the speedo output, in which the KA is calibrated for MPH and in Japland where the SR's read out in KPH... it will make you think your going faster with the wrong sensor...
