Blown240sx wrote:Why is that? Id see a good reason. The cold pipe would give you a colder intake temp (better power) and better for the turbo since it cools to some effect. Plus the recuiculate will help with the ooo so common RPM drop when you clutch in.
well what im saying is that when the bov is mounted on the coldpipe its somewhat like if you were to have it mounted on the hotpipe but also have it recirculated..when the bov is on the coldpipe you have quicker throttle response even when its not recirculated thats why there is no need to do it..also not all engines rpms will drop down if the bov is vented. some engines drop right to idle and stop no bouncing around until it gets steady...others will bounce around until steady and some will just die right out and therefore must be recirculated. if you do have that problem then yes its a very good idea to recirculate, pretty much a must
