does it have less power
nissanboy91
Car: 91 nissan 240sx
i have a 91 nissan 240sx coupe and my ka motor blew up and i got another ka motor but it was a automatic motor and my car is manual but i got it all hooked up but what i was wondering is does the automatic have less power will it be slower..
onosqv
Car: '92 240sx Vert
why don't u just keep the transmission but replace the engine? only the engine blew up & not the transmission rite? Doesn't make sense to do a manual -> auto conversion for most ppl...
And yes, auto's suck up a lot of power, relatively.
SeanC
Car: 1993 240sx SE
i am pretty sure he took a ka out of an auto and swapped it into his manual 240sx.
onosqv
Car: '92 240sx Vert
Ok, then he was wondering about the automatic engine vs manual engine??? I was thinking that afterwards, but it just didn't make sense.
nissanboy91, if you were wondering that, the engines are the same btwn auto & manual (there are slight differences in regards to diff years, but that's another story), just the trannies are different... perhaps more descriptive writing next time w/ some better punctuation? .
p.s. welcome to the boards.
nissanboy91
thanx alot dude thats all i needed to know.. but also i got a AEM cold air intake and full exhaust how much horsepwer do you think i could get with that?
onosqv
Car: '92 240sx Vert
about 5-10 whp if you are manual and if by full exhaust you mean header/hi-flow cat or test piped & catback. if just intake/exhaust... you are looking around 5whp.
nissanboy91
i have no header yet but from my down pipe back it is 2 3/4 piping with no catilitic converter or anything just straight back with a canester.. how much power with that?
180fan
Car: 89 fastback
Removal of a catalytic converter has very little to no gains from what I've seen unless you've got a highly modified engine. If you're talking about just a header, I'd suggest leaving the cat on. You can't just make broad generalizations with an exhaust. Not all exhausts will make power. There are sacrifices generally with low end power for top end or vice versa. Dyno your new exhaust instead of asking for broad numbers that may not reflect the performance gains from your particular exhaust system.
