does ground wires matter
916drifter
Car: 1990 240sx Fastback
I looked under my car and the ground wire after the cat is not connected. It is cut and can't b connected. Does this have to do nething with nad gas mileage?? someone told me it did but i dunno for sure. if i need a new one where can i get it..
allthrottlenobottle
Car: 91 s13
when i had my resonator removed i asked the welder the same question and he told me it doesnt matter so i never hooked it back up. if you really want it hooked back up go to a junk yard and get one cause the dealership probably charges an arm and leg for it. any autoparts store would have a braided style ground wire with connectors as well.
ride4lame
you can definitely get a new ground strap from car parts or pepboys etc. If the engineers put it there...there might be a reason.
NISTECH
it is an added ground to keep the exhaust grounded since it is hung by rubber gromets. you can always get a yellow eyelet cut the plastic peice off it crimp your braided wire in it add soilder and reattach it to the bolt it broke off of.
S13240
Go to your local autozone and purchase a universal grounding strap.
