Does doing an sr20 swap cause the odometer to show tampering evidence?
dxevin
Hey guys, im buying a 240 from cali possibly, and its a 95 with a 2001 s15 sr20det engine swap, and i did a private inspection through ebay (because im in hawaii) and the inspection showed that the odometer has been tampered with. I'm just wondering if that is from engine swaps or if its totally unrelated. Thanks for your help
thefro526
Car: BMW 325Ci & S13 Coupe
dxevin wrote:Hey guys, im buying a 240 from cali possibly, and its a 95 with a 2001 s15 sr20det engine swap, and i did a private inspection through ebay (because im in hawaii) and the inspection showed that the odometer has been tampered with. I'm just wondering if that is from engine swaps or if its totally unrelated. Thanks for your help
There's a lot of things that could be in play in this situation.
1) The owner could've swapped clusters to reflect the mileage of the engine or for ascetic reasons. (Pretty common)
2) The owner changed the original odometer to reflect the mileage of the motor. (Never seen it but it makes sense)
3) The odometer didn't work for a while so the mileage is wrong. (It happens)
4) The inspector could be wrong.
It all depends though, why does the mileage matter to you? Do you plan on replacing parts that deteriorate over time (Bushings, seal, etc) or would you rather have a lower miles car? Personally the mileage wouldn't matter to me.
dxevin
thanks for your help so an engine swap does not affect the odometer correct?
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
nope
dxevin
not correct?
Razi
Car: Moo
It does not affect it.
Dattebayo
Maybe you should say it in Hawaiian.
Lev_96_240sx
Car: 96 240sx
Pololei 'ole
