i240sx wrote:i got coilover with pillow mount up front. i was just wondering does the pillow mount set the alignment automatic or does i have to set it? thanks people
You unscrew these 4 bolts that holding the plate and slide the plate in and out. If you slide the plate toward the engine, you will have minus camber. Alignment shop will do this for you. But before that, you need to do some research on alignment settings. What do you want? Drift, grip or daily drive??? Alignment setting depends on what you accomplish.
