Does anyone's floorpan get HOT?
Gladius
In my 240, the floorpan around the transmission gets really HOT. I was wondering if this is a common thing? It gets warmer as the engine warms up, but doesnt gets hotter when i drive hard. Nor does it cool down if I were driving it hard. Its constant.
180fan
Car: 89 fastback
around the transmission or at your drivers area? Mine gets pretty hot in the area around the footwell of the driver because the exhaust runs under there and usually I feel that on my 50 mile commute.
Projex240
Car: Dogs , My RIDE
its from your exhaust genious's--lol--j/kSometimes--youll get a car from soeone ho took it in for service for a "rattling" noise. That noise is caused by the exhuats heatshield. The shop will usually remove it as will most other(like me) to shut the rattle up. It then gets just a litle warm fomr the heat radiating from the exhaust piping.
ride4lame
i get that. its nice in the winter cus i have no heat.:)
s13sr20chris
check your cat. i have seen some bad cats caused by poor running cars. they came in with the carpets smoking and the cats were glowing red.
Gladius
I know for sure its not the cat..;) Its not the exhaust either because its not getting hot just under the driver's side floorpan. I probably should have been more specific, on the hump in the floor board under the dash and center console is where the most heat radiates, definantely coming from the transmission. I was just wondering if my transmission was over heating from just regular driving. I mean it gets pretty hot. Hot enough that i can't touch the the metal "hump" for more than 3-4 seconds.
Gladius
ride4lame wrote:i get that. its nice in the winter cus i have no heat.:)
Well, its spring/summer here now and almost the whole year 'round. My right foot is always hot, plus its getting into the 90's. :eek:
slw240sx
Car: 1990 Ca18det 240sx Hatch
do you have any leaks where the cat bolts in?
i know in my car i had a burnt gasket no heat sheild, and my motor loved to spit flames since it was overly rich. i ended up catching my carpet on fire because it shot a flame into a screw hole that had the carpet covering it .
s13sr20chris
m/t? should not be hot. a/t? maybe, but not that hot.i would have to see it. try driving for 20 mins then jack it up and look under there. if the floor is getting too hot to touch, then something under there should be like really really hot.
Gladius
slw240sx wrote:do you have any leaks where the cat bolts in?
No leaks and no carpet.
Zadok
Car: '99 30th Aniversary Legacy L
Carpet is usally a good insulator, put the carpet back in and your problem may be solved!
slw240sx
learn to like it warm
wrap the DP and cat in heat wrap
180crafter
Car: Nissan 240sx
Projex240: Right on the damn money.
I used ot have a regular 240 with that dame rattling, Removed the heat shield and wham no noise.
I never thought anything of it, but I like to drive with my shoes off. Well, burned a hole in my foot.
Cure: buy some of that aluminized heat sheilding crap that attaches to the bottom of the car. Works like new.
