Does anyone know why dash board vent won't sit flush
Q45-pj
Car: 2000 Q45 anniversary edition. Grey/black leather.
This is the piece in question. It just won't sit flush like the other one. Can't wait to hear what you guys think.
qship96
Car: 1996 Infiniti Q45
sun warped plastic due to heat or a broken clip on the plastic vent piece.
Q45-pj
Can I just replace it? What is the part called?
Thanks for quick response.
qship96
i would think so,the part just snaps in.might be called defroster vent diffuser or something close to that- stop by your local dealer and they should be able to pull up a diagram of the part and quote you a price.
tfvesquire
Car: 1998 Q45
You don't have to buy a replacement vent piece. I had the same issue that I fixed five years ago and it is still in place. Just fix it yourself.
Carefully pry up the vent the rest of the way and remove it from the dash. Don't forget to unplug the light sensor on the dash. Use a heat gun or even a hair drier on hi heat and aim it at the vent clips on the underside of the piece. Don't hold it there too long, just enough to soften the plastic clips a little. Once the clips are hot, carefully push them using a screw driver just slightly and hold them until they cool. You can also move each of them about 1/8" out and then spray the clips with cool water to "freeze" them in place.
Then just dry it, plug in the sensor and reinstall. You will know if you moved the clip enough if the vent stays in place and doesn't pop up again.
Good luck.
Ted ;)
