fuiousgreen wrote:im having a problem with my instrument cluster. out of all my gauges in the whole thing .the only one that is working is the tach in the center and it only works every once in a while .i think i need to replace the whole cluster
You sure it's not the wiring harnesses? Have you ever taken the cluster out or did an engine swap? I had the same problem as you did. My fuel and temp guages didn't work at all, the speedo almost never, and the tach was intermittent. Took the cluster out, one of the plugs on the cluster harness that runs into the dash harness was only halfway in. The main dash plug that connects to the ecu harness wasn't completely locked in, and my fuel level swing arm in the tank somehow got locked in one position when I did a fuel pump replacement.
