Does anyone know what each wire is for off the rb20 A/C compressor?
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Hello, ive got pretty much everything i need for the a/c install i just need to get my compressor to kick on, ive read frosted flakes write up but its not working for me. Thanks!
Wulfgang
There is only one wire you need... the one coming from the clutch itself. The other plug is for a pressure switch, which is unneccesary (redundant) in a 240SX.
RB20DETodd
Wulfgang wrote:There is only one wire you need... the one coming from the clutch itself. The other plug is for a pressure switch, which is unneccesary (redundant) in a 240SX.
Thank you sir, so if i give it a 12 volt source it should click on? Im assuming it the plug closest to the radiator?
thanks
Wulfgang
RB20DETodd wrote:Thank you sir, so if i give it a 12 volt source it should click on? Im assuming it the plug closest to the radiator?
thanks
Yes, connect it to your original A/C clutch plug (which is routed through the A/C clutch relay).
