does anyone know the wiring diagram?
rjuarezjr915
Car: ROGUE
I am looking for the diagram so that I may hook up an audio output i just need to know what wires go to the rear speakers.
kots
kots wrote:
i don't have the bose option. i'm not sure if this what you need. this is the color code from the wiring harness to aftermarket stereo.
12V Ignition / Acc. . . . . . . . . . Red12V Batt / Memory. . . . . . . . . YellowGround. . . . . . . . . . . . . . . . . . Black*Power Antenna. . . . . . . . . . . . BlueAmp Turn-On . . . . . . . . . . . . . Blue / WhiteAmp Ground. . . . . . . . . . . . . . Black / WhiteIllumination . . . . . . . . . . . . . . OrangeDimmer . . . . . . . . . . . . . . . . . Orange / WhiteRight Front (+) . . . . . . . . . . . . GrayRight Front (-). . . . . . . . . . . . . Gray/ BlackLeft Front (+) . . . . . . . . . . . . . WhiteLeft Front (-). . . . . . . . . . . . . . White / BlackRight Rear (+) . . . . . . . . . . . . VioletRight Rear (-) . . . . . . . . . . . . . Violet / BlackLeft Rear (+) . . . . . . . . . . . . . GreenLeft Rear (-) . . . . . . . . . . . . . . Green / Black
The above information is from the Metra dash kit manualhttp://www.installer.com/pdf/95-7425.pdf
PCY
The above diagram doesn't explain scrap. It's got no explanation our vehicle terminals, only aftermarket terminals with regular set coloring codes. You'll need to see the FSM for the wiring diagrams. Also, you'll need to make sure if your vehicle is with BASE or BOSE Audio systems. If BASE, it'll be a whole lot easier. Since BOSE system runs a different impedance setting, your aftermarket radio may/may not function at full mode with the factory speakers.
-Peter-
rjuarezjr915
Car: ROGUE
its for the base stero. any help is great.
philipa_240sx
Read the 'Rogue Glossary' sticky at the top of the forum. There is information (rather a hint) on how to download the Factory Service Manual with the wiring diagrams for free. It's about halfway down the following post:
zer...26642
I won't explain the whole process to you as the manual is located outside of this forum... and I don't want to promote the competition ;-)
Return to “Rogue Forum”
