Does anyone know the base's 5 speed gear ratios & final drive?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
boxcarbill
Car: '07 Versa SL hatch 6 speed white/beige int.
scooterbob
Car: 2008 Versa, 1995 200sx
From 6th to 1st:
Turtle on drugs, turtle, snail on drugs, snail, slug, and dead slug.
scooterbob
zer...34597
This post didn't give ratios, but it talks a decent amount about it.
boxcarbill
Maybe the damned thing has more overdrive than my 6 speed SL.
biggie
boxcarbill wrote:Maybe the damned thing has more overdrive than my 6 speed SL.
Its still a european designed transmission, probably the same it not worse on gearing than the 6 speed.
They Call Me Whatshisname
Car: 2006 Nissan 350Z
Lol I think you have about a 500 rpm diff in 6th gear than the 1.6l 5th gear.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
boxcarbill wrote: ?
Base 5 speed:1: 3.72722: 2.04763: 1.39284: 1.02945: 0.8205Final: 4.0666Reverse: 3.5454
Compare to 6 speed:1: 3.7272: 2.1053: 1.4254: 1.1715: 0.9716: 0.811Final: 3.933Reverse: 3.687
boxcarbill
more overdrive on the 6 sp especially considering the larger diameter tires.
Return to “Versa Technical Discussions”
