does anyone know?
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
i need the part number for the stock s13 sr20det ngk platinum plugs. HELP!THANKS,
Rex
Car: None
Did a little searching and found this ...
SR20DET NGK PFR6B-9 This is an original platinum tip and resistor type plug and is fine for standard boost, should never need changing. Gap is set to 0.9mm
Let's see if anyone disagrees??
quiksilvia
Car: 95 s14 se
wrongnissan part # 22401 02p16ngk # bcpr6e-11
SpeedRacer1
Car: 1990 240SX, G35
Quik theres no need to be so harsh especially when you are the one who is completely wrong here.
NGK BCPR6E-11 is the spark plug for the CA18DET without a catalytic converter. NGK PFR6A-11 is the spark plug for the CA18DET with a catalytic converter.
BTW the Nissan part number (22401 02p16) you gave doesnt exist, try again.
Rex is right, a further not is that PFR6B-9 is that standard plug. You could also go to hot (PFR5B-9) or cold (PFR7B-9) plugs depending on the type of driving you do.
Sources: http://www.google.com http://www.a-pp.com/shop/ngk_nissan.htmS13, S14 and S15 FSM http://www.users.bigpond.com/w...e.htm
ImportIntelligence
Car: Big turbo's :)
Also, if you are getting these plugs in the states, most of the time you will have to order them as simply PFR6B or PFR7B. NGK tells me this is a european plug and limited gaps are avail in the USA.As per the FSM, the PFR series is correct.
quiksilvia
Car: 95 s14 se
i realized i was a lil mean, but those numbers are off of a ngk, nissan dealer box. its the plug i got from nissan when i redid my head, but i dont remember what influenced me to get that number, if it is in fact the incorrect number.
