Does anyone know
tony/ka24de
There is a plug on the bottom of the engine block on the drivers side near the motor mount. Does anyone know what this plug is for? I was wondering if it would be useful for my oil lines I need to run for my turbo setup. Does anyone know if I can run my oil return line for my turbo to my dipstick hole? For my turbo oil lines I am thinking of going with a 1/4"inlet, and a 1/2" for the outlet. How would this work out?
tony/ka24de
its a t3 turbo
KApwr
tony/ka24de wrote:There is a plug on the bottom of the engine block on the drivers side near the motor mount. Does anyone know what this plug is for? I was wondering if it would be useful for my oil lines I need to run for my turbo setup. Does anyone know if I can run my oil return line for my turbo to my dipstick hole? For my turbo oil lines I am thinking of going with a 1/4"inlet, and a 1/2" for the outlet. How would this work out?
That plug is a to drain the coolant out of your block so don't do it!!! Also, you can't use the dipstick for a drain cuz it's wayyyy too small!!!! Drop the pan dude and do it right:)
GirlRacerS14
Car: Cars and motorcycles and racing both of them hard and fast
Yeh make sure you use a nice sized return line straight to the oil pan. It's not hard to have a flange welded on. Besides, if you don't you'll get too much pressure and blow the seals out in your turbo. Not worth it for something so minor as a good return line.
GR :)
tony/ka24de
what do you think about the sizes of the oil lines?
WDRacing
GirlRacerS14 wrote:Yeh make sure you use a nice sized return line straight to the oil pan. It's not hard to have a flange welded on. Besides, if you don't you'll get too much pressure and blow the seals out in your turbo. Not worth it for something so minor as a good return line.
GR :)
:boink
Thats my girl.....
