240z4u »
https://forums.nicoclub.com/240z4u-u26156.html
Tue Jun 27, 2006 5:37 pm
Guys, it does appear that 100% of the wiring is the same as long as you do not cut any of it out! I was meticulous about that when I did my harness.
I can hit my cruise on switch on my dash (s14) and if I hit the set button the cruise light on the dash comes on. I did not used to have a speed sensor, and when I did it then it made it flash.
I suspect it will be a matter of sorting the throttle body, and wiring up kill wire to the clutch (If the switch for the brake lights is seperate from the cruise switch I may grab it there).
I also have to make sure there is no wiring disconnected from when I pulled the auto that will prevent everything from working as it should.
I promise I will do a writeup on this when I get it working.
Evan
BTW, how did he add another channel to his? I can always use that as a last resort.
