DOES ANYONE KNOW IF YOU WILL GET BETTER ACCELERATION WENT
que cogones
Car: versa
DOES ANYONE KNOW IF YOU WILL GET BETTER ACCELERATION WENT YOU CHANGE MUFFER TO A Round Straight Cut Bevelled tip, 2-1/4" inlet, Round Stainless Muffler, 4-1/2"dia. x 4"L tip, Overall Dimensions 6"X6"X20"
(MAKING A ENTIRE NEW MUFFER FROM THE TIP UNDER THE CAR )
jamied311
Car: 91 Nissan 240SX Fastback
umm.. I don't think so.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
No, you will not see significant power gains by changing just the muffler itself. You would need to change the entire exhaust system to make it worth your time and even then the horsepower gains would be minimal at best.
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
You might... might... see a small improvement at high RPM's... but any gain there, will most likely result in reduced pwoer at lower RPM's... where you actually use the car most of the time.
Of course changing the muffler will make it louder, which will could make it feel faster.
proxim2020
You'll definitely sound and feel like you have more acceleration, but you really won't have anything. If you want you see improvements, you'll have to work from the head to toe. An intake will help pull the air in more freely, while a turbo will force the air in. To get the air out heads, cats, pipes, resonators, and mufflers designed to get air out quickly will help a ton. Changing out one part normally gives you a very small increase since you haven't resolved your bottleneck.
blackversaatl
Technically, yes, but it's SO SMALL you won't even really notice anything. It won't be worth it performance wise, but cosmetically and sound speaking, it will add like a million horses to the wheels LOL
If you're doing it for looks and sound, go ahead, but if for performance, you're gonna have to AT LEAST do an Axle back to gain anything at all.
The Versa is kindah cocky, peppy, or whatever, but it's not highpowered or forced-induction (turbo/supercharger) so you won't get much gains without replacing entire or near entire systems on the car.
