Does anyone know how to do basic maintenance?
dfintegra
Car: 2004 Infiniti G35
Does anyone know how to do basic maintenance, like oil change on their G35? I upgraded from a 95 Integra to 2004 G35 and the engine is totally different from what i'm used to. Any pics or details on fuild change or spark plug change will be very appreciated cause this recession is a pain.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
Oil change takes 10 min with proper tools...
You need:
RampsI think it is a 14mm socketI like the Plier style oil filter wrench.Oil pan
You will need a new filter and 5 qts of 5w-30(your auto parts store should be having sales and they can help you find what you need)
As for the plugs... well they last over 50k miles... so I haven't had to do that yet.
DJ
telcoman
Tampa G35 Sedan 6MT wrote:Oil change takes 10 min with proper tools...
You need:
DJ
I've got 88k and haven't touched my plugs
dfintegra
You may want to consider acquiring a decent set of tools
http://www.sears.com/shc/s/p_1...nchor
Do not use the jack that came with your vehicle
See the owners manual for the location of the jack points under the vehicle
I've done 27 oil changes thus far on my G. I purchase the oil, air, and cabin filters at the dealer. I use 5w-30 Pennzoil, Valvoline, or whatever is on sale and change it every 3k-3.5k miles.
I also rotate my tires every other oil change
In addition to ramps get a decent 4 ton hydraulic jack as well as jack stands. My photobucket account does not seem to be working so I can't post pictures. My previous posts on this topic are not showing previous pictures that I posted so I don't know what is wrong?
The fiberboard shroud underneath blocking access to the oil filter has around 14 10mm bolts to remove it. I use a cordless drill with an adapter for the 10 mm 3/8 drive socket. When you purchase the oil filter you will need a cap wrench to remove the old oil filter. Take the filter into any auto supply store to get the correct size.
Although initially you will spend a few hundred for all the necessary tools over time you will save a considerable amount of money.
The best part is the wife leaves me alone
Telcoman
Modified by telcoman at 7:40 AM 5/16/2009
Modified by telcoman at 2:25 PM 5/17/2009
Modified by telcoman at 2:31 PM 5/17/2009
Modified by telcoman at 2:38 PM 5/17/2009
Modified by telcoman at 2:40 PM 5/17/2009
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
dfintegra wrote:Does anyone know how to do basic maintenance, like oil change on their G35? I upgraded from a 95 Integra to 2004 G35 and the engine is totally different from what i'm used to. Any pics or details on fuild change or spark plug change will be very appreciated cause this recession is a pain.
Welcome to Nico!!!
I recommend: a set of Rhino Ramps from Autozone a Kobalt set of 3/8 inch metric tools from Lowes a oil catch tub from NAPA a 5 qrt jug of Mobil 1 from Walmarta Nissan oil filter from.....Nissan
Did I miss any of my sponsors???
Yes, NASCAR is in town!!!!
