dickie »
https://forums.nicoclub.com/dickie-u32299.html
Wed Oct 04, 2006 10:37 am
get 6 bulbs when you go to the store/order them. they should come in packs of 2. its nowhere near as easy as other cars like civics/integras. to remove the bezel you will need to remove the kickpanel and drop the lower cover under the wheel, remove 2 nuts and 2 bolts supporting the steering column to drop it low enough to remove the bezel, then remove the screws holding the bezel itself with a short driver.
