Does anyone know how much HP motors in a turbo'd 280zx put out?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
iwannaRB26dett
Car: 1995 240 sx se
n e 1 know how much HP motors in a turbod 280zx put out and if they r decent motors to work with and swap into a 240sx se s14 95?
safxtacy
Perfect place to ask this.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
go find the tech section and ask it there
Raxephon
Car: '04 RX8...for the moment...
iwannaRB26dett wrote:n e 1 know how much HP motors in a turbod 280zx put out and if they r decent motors to work with and swap into a 240sx se s14 95?
180HP @ 5600rpm
zeroforum/194http://forums.nicoclub.com/zeroforum/167
http://www.zdriver.com/forums/...15404
They are great motors, but they are rear sump and the 240sx is front sump.
Modified by anlasak at 11:20 AM 12/19/2006
Raxephon
safxtacy wrote:Perfect place to ask this.
It is. It is a transplant consideration for a 240sx, and this is still the 240sx forum.
MeanGreenS13 wrote:go find the tech section and ask it there
Its not a really technical question so it shouldn't matter whether its posted in zeroforum/44 or if its in zeroforum/17.
Being too lazy to help someone is just as bad, if not worse than, being too lazy to search.
dickie
Car: Killer Turtle
we also would have accepted "classic z" or "datsun" as an excellent place to look for L-series motor specs
also, im pretty sure that you would spend way more than would be practical to swap the motor and in the end could have paid for a decent ka turbo setup or an sr swap.
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Fixed the retarded thread title and moved to the correct forum. Have a good day.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
keep in mind those are stock low boost power levels, mine has 299 at the wheel (see sig) 400 whp is possible with the L28ET (thats the 280ZX Turbo motor) to get there you need Ijectors, larger turbo, managment system, I/C, and headstuds with a metal HG, at which point the stock cast pistons are really pushed to the limit and are due to melt at any time, there are a lot of 400 whp L28ET's runing around, my motor is a 183k mile junkyard motor loosing compression in #2, after a fresh bottom end I'm making a run for 400
and yes it would likely be cheaper to turbo the KA but I'm not familiar with it's limits but I'ms sure you'd end up buying all the same parts except the mototr is already in your car, I'm a fan a turbo'ing a stock configuration over a motor swap especially when that swap yeilds less displacment, If I had a 240SX I'd turbo the KA, Ive done simple and radical engine swaps and unless the stock power plant is a real dawg unable to support the desired power it's gonna be cheaper and easier to build on what you already have
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
For the non-intellectually challenged, a translation:Does anyone know how much HP the 280ZX turbo had? Are they decent motors to work with and swap into a 95 240SX?
Return to “Datsun Z Forum”
