Does ANYONE have these on a black ac??
All things Altima Coupe.
Coupe12
Car: Nissan altima coupe. 2008, 2.5S
http://store02.prostores.com/servlet/sa ... CFL/Detail
Even if someone with good photoshop skills would be great, I would just like to see these on a black coupe. Thanks :)
czonin
Car: White 09 Altima Coupe 2.5S
Those are fairly new don't think anyone has those particular ones but there definitely are some black coupes with the housing blacked out. Theres another thread here about those so make sure you read up before you buy them:
08-09-altima-2dr-ccfl-halo-projector-t532256.html
DAAN.
Those look good
Halogen bulb only
Ranga14
Car: Boosted 08 Altima Coupe 3.5
wow, that's my next purchase.
downedzephyr
Car: 09 Altima Coupe 3.5se
definitely interested. i'd want to see pics installed first though
czonin
Make sure you guys read the thread I linked. Dangeris was talking about some of the materials used in those. Might be a bad decision in the long run.
nmiller17
Car: 3.5 Altima Coupe CVT
$1000 for projectors? Ouch.
nctrevor24
Car: 08 Nissan Altima 3.5 SE Fully loaded
I still havn't had anyone answer me why these won't work in an altima with factory HIDs and what mods would have to be done to make it work :/
InfinitiEric
nctrevor24 wrote:I still havn't had anyone answer me why these won't work in an altima with factory HIDs and what mods would have to be done to make it work :/
They will work with your factory HIDs (as long as the bulb size is the same as the non-HID size), but they will cause an enormous amount of glare.. so much glare that you probably won't be able to see the halos surrounding the bulb. HID bulbs should be placed in an appropriate HID projector to reduce and/or eliminate glare and these headlights have halogen projectors, so you will have glare. That's the only downfall.
nctrevor24
Thanks for the reply! I dont even care about the HIDs at this point ill use the bulbs provided with the headlights but for some reason people have made it seem that they cant even be hooked up whether you want to use the HIDs or not is the wiring different?
InfinitiEric
I can't really speak to that.. if the headlights are designed for your car model and year then the wiring should be okay. Keep in mind that if your Altima has HIDs you will HAVE to use HIDs inside the headlight unless you want to completely swap out the headlight electrical system for halogens, which is a ridiculous amount of work.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
InfinitiEric wrote: They will work with your factory HIDs (as long as the bulb size is the same as the non-HID size)
actually i think it clearly says in the item listing that they will NOT fit with factory hid.
those headlights say that the come included with the h7 projects for lows and h1 for high bulbs, won't these just be plug and play? unplug your old headlights and then plug these into the factory wiring harness?
nctrevor24
InfinitiEric wrote:I can't really speak to that.. if the headlights are designed for your car model and year then the wiring should be okay. Keep in mind that if your Altima has HIDs you will HAVE to use HIDs inside the headlight unless you want to completely swap out the headlight electrical system for halogens, which is a ridiculous amount of work.
Thats probably exactly why they wont work In the description of these headlights on ebay they said you have to use H7 bulbs and its not compatible with HID models Thanks for making me understand why they won't work guess ill have to wait for and aftermarket HID headlight to come out althought i did see dangeris's work which looked amazing but I've had my old headlights modded from my old car spent $1300 on them just have have the glow kit in one side go out completely and a few leds out within 2 months which after the company would not reply to my emails *cincitydesigns dot com*
nctrevor24
Right I did read that but I just wanted to understand why
InfinitiEric
nctrevor24 wrote:I've had my old headlights modded from my old car spent $1300 on them just have have the glow kit in one side go out completely and a few leds out within 2 months which after the company would not reply to my emails *cincitydesigns dot com*
I know quite a few guys from Cincity. There good guys from my interactions with them and hold true to their word. Try giving Nic (the owner) a call at 701-440-1801.
nctrevor24
They were always nice, this was the only incident the entire time dealing with them i was disappointed. Regrettably I no longer have the car the lights were for but I'm not trying to get money or anything from them I just wish they were there when i needed them, no hard feeling towards them at all.
Didn't mean to bash them if it came off that way.
