Does anyone have or sale new main caps for RB25?
exodus5547097
eh?
Doubtful, there is no separate p/n for the main caps/girdle that I can see. Plus line boring is $$$..
jdmser
Car: duh
Is this what your talking about? This came off a RB20 block that no good anymore. I'd let you have it cheap but, eh? is right, your going to spending some money to have it line bored. I'm not 100% this will bolt to the RB25 block either, maybe someone else could chime in on that. I do know the mains are the same size.
exodus5547097
well I have a fsm for it and it turns out to be cam brackets but no, rb20 and rb25 cam brackets are not similar. But thanks for helping out.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
in other words you are looking for the camshaft caps (aka cam caps). Main caps are referred to the girdle which was posted above that holds the crankshaft to the block.
Replacing either will require line boring as mentioned.
eh?
Do you need a whole set or just a couple? What happened?
exodus5547097
bought the motor with cam caps off and not marked. How can I tell which ones which? about a couple were off.
eh?
They should be stamped I1-I7 and E1-E7 right on the top. All my RB25's had the caps stamped. You gotta make sure you put the cap in the right direction too.
Chaos the Xile
Car: 1974 Datsun 260Z
eh? wrote:They should be stamped I1-I7 and E1-E7 right on the top. All my RB25's had the caps stamped. You gotta make sure you put the cap in the right direction too.
Yes and you can dowload a full service manual(fsm) that will explain to reassembly of the head in detail
exodus5547097
thanks a lot guys!
Bluefire
Also cam caps all face toward the exhaust side. Ie.. you should be able to read the stamp marks properly if you were standing on the exhaust side.
-BLuefire
exodus5547097
what about the intake side? are they marked also?
eh?
Yes they are all marked.
exodus5547097
thanks because this shop i have been didn't check but asked me first.
squbafreak15
Car: 89 240sx rb20det
on some rb20s there not marked it really blows. pretty much easyer and cheaper to get a new head w. cams valves and caps. plus then you have backup valves
