does anyone have experience with ca18et
noob2nissan-s12
Car: 1984 200sx turbo
im working on a ca18et anyone know much about them ...
turbos12
Car: 1985 nissan 200sx
i have 1...im pretty familiar with them..but i swapped mine out for the det..join club-s12.org...whats wrong with ur ca18et?
Indecisive
Car: 1987 200sx Turbo
I'm the same as turbos12. What's your issue?
I also second joining club-s12.org and checking out the ca18et section of the forums.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
i would think it is pretty much the same as a DET, in concept.......
then again you dont even have to know a specific motor to know how to solve alot of different problems and/or diagnose what is wrong.
m_wolfenden
Car: nissan 240sx
yea i imagine it would be like a ka24e to a ka24de......just a little different.....awww my ca18det it buried in snow int he back....so sad
bradt
Car: 1989 240SX CA18DET
m_wolfenden wrote:yea i imagine it would be like a ka24e to a ka24de......just a little different.....awww my ca18det it buried in snow int he back....so sad
That is a MAJOR CA foul dude.
articzap
Car: 2014 F150 FX4
My CA 240 is under a foot of snow. Meh.
m_wolfenden
Car: nissan 240sx
yea well....if it makes u guys feel any better,....their is an Sr20 sitting right next to it in the snow also.....and we got like 20 cm today so they are really buried
themadscientist
Hit the SR with a sledgehammer and I will feel better. On second thought just rev it past 8K a couple of times, that should kill it.
float_6969
8K? I think a couple of seconds off of the 7500 rpm redline will do it!
themadscientist
Kill it, don't make it suffer. 7.5 is a slow bleed gut shot, 8 and up is more humane, right to the head.
noob2nissan-s12
the ca18et has a single over head cam. i want to know if anyone has gone to a dual over head cam and hoe it was achieved granted the ca18et has 8 spark plugs how can i go to dohc with out the 8 sparkplugs?
themadscientist
If the CA18E is anything like the CA20E then the crank snout is different preventing the DE's cog fitting, and the head bolts are M10 instead of the DE's M11. The timing belt tensioner is in the wrong place which means drilling and tapping the block for the DE tensioner. All around it is not worth it. I am very confident a good condition CA18ET could crank out 200hp with an S14 turbo, some bigger injectors, like 444cc RB26 ones and a proper intercooler.
float_6969
The CA18ET block probably isn't worth the trouble. For the time and money you could pick up a good condition CA18DET and put it in your S12. It's been done plenty of times, and most of the serious S12 guys end up down this path.
RS12Turbo
float_6969 wrote: The CA18ET block probably isn't worth the trouble. For the time and money you could pick up a good condition CA18DET and put it in your S12. It's been done plenty of times, and most of the serious S12 guys end up down this path.
All too true......I dumped 2k on a remanufactured ca18et and only got 160whp out of it, and ended up bending a rod with only 12k miles on it in the end. HUGE waste of money....don't bother.My ca-det is running strong 2+ years.....knock on wood
noob2nissan-s12
im rebuilding the engine and im not going to be going the easy way thats just me i like to be different and it depends on what you do to the block, head, pistons, gaskets, valves, valve springs, and other little things i learned from some enginebuilders.. BUT THATS JUST ME..
sideways danny
Car: s13, CA18DET
The ET is a great little engine, I've had great fun with them.
DET rods and pistons are the first thing to fit though, the ET items are both chocolate.
Heads are pretty bad as standard, you'll never make BIG power with one but you can do reasonable things with some sensible porting.
If you want a 16v, just use one form the start. I'm just awkward and like "the underdog"
themadscientist
put CA18DET pistons, rods and main cap girdle in the CA18E block. That would solve a lot of the trouble right there.
