elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Jun 13, 2007 4:47 pm
ok I went out and did some measurements, these are pretty conservative and pretty rough as well.. On the drivers side from the frame to the first point of contact right above the precat is about 8.5 in, lets call it 8 to be safe. On the passenger side its about 7in. I dont know if you could run a 2in pipe on the drivers side with the manifolds in the way, the passenger side is close, you might be able to smash a 2 in pipe so its oblong to get it to clear, but once its past the manifolds its home free, theres nothing else in the way that couldnt be moved a tiny bit... The drivers side is doable theres just a bunch of crap in the way that makes it tough to tell.. It makes it a lot easier to tell on my Q since the battery is already removed.
The next option is flipping the exhaust manifolds and mounting the turbos where the battery and airbox go. That might be an easier setup and youd get much better oil draining... However it might be tough to plumb the downpipes... Also another question is will the manifolds clear the engine and the frame? Maybe? its hard to visualize that, youd almost have to slide the motor in with it like that. However youd have a mile of clearance from the X member. Honestly, i dont really like this setup that much because id like to go as stealthy as possible on a Q. If its our only option, fine but id like to have them tucked away where only the trained eye can see them.
Dual 3in exhaust would be pretty sexy on a Q
Also, as a side note I dont really think that making custom manifolds will really get you anywhere if you wanted to mount the turbos toward the back of the motor under the motor.. I dont really think you could mount the turbos much higher than what the stock manifolds would let you because then youre basically in the head. I didnt measure vertical clearance ill save that for another time.
All in all, regardless of what people say I think this is a very possible project, and with the motor on the stand mounted to the X member a lot could be told. You could probably almost plumb it up entirely on the stand keeping everything as close to the motor as possible.
