nismo1118 wrote:Anyone else having trouble locating a R33 ps pump to do the delete correctly.
Teggyroadspecialist wrote:No idea if R33s are the same but, I read that you can just loop the pumps on a R32 and it'll work fine.
It's not easy to find an R33 pump because they didn't make nearly as many 33s (or 34s) as 32s. The R33 and R34 pump are the same single stage pump. You can buy them new from Japan but they're $1K so that's why I was glad to find my R32 already had one since used pumps are pretty rare, even from overseas wreckers. You can close off or loop the second-stage of an R32 pump when deleting HICAS but I needed a proper single-stage pump to fit my new top-mount turbo kit. You can also use an RB20 or RB25 single stage pump as an alternative to an R33/34 RB26 version but whichever one you use you'll need the matching mounting bracket and a new inertial damper because the spacing and belt sizes are different from the R32 RB26 double-stage PS pump.
