float_6969 wrote:To be honest, if you already have a SAFC, I'd just keep using that. I don't think there is any reason that it can't compensate for the MAFS and the injectors. I mean, if you didn't already have one, then I'd pick a burn over a piggyback, but if you've already spent the money, then why spend it twice?
Well, yes, I already have it. That is true. Here is my reasoning and tell me if it makes sense:
If I just throw the 550s and MAF in there, there is no way for me to tell if my settings are accurate without going to a dyno and spending who knows how long getting it all setup. With the eprom, I can compensate for it all right there and then use the SAFC to fine tune it on the dyno. That is my only reasoning.
I am coming over from the DSM world where things are EASY. I mean hell, I had a palm pilot that plugged into my consult port and I could read the timing, fuel trims, O2 coolant temp, air temp, barometric pressure, rpms, etc...for a total investment of about $120. Even did logging. If I had that kind of stuff, I would be set. And unless I come into some money, there will be no multichecker or mdm100 for me. I'll probably be asking a bunch of questions when the time comes. BTW, the 550s and SAFC are coming from the eclipse... so at least I could salvage something out of that POS.
