:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Fri Sep 12, 2003 2:20 am
Search on here, and check the Freshalloy.com Advanced 240SX forum...
Doing a KA-T on a '97-98 only has 1 difference as compared to any other year with a KA24DE...and that's the ECU setup. If you want to run JWT, then you have to use a '96 ECU (you can't re-program '97-98 ECUs) and move 3 pins on the wiring harness (at the ECU plug)...
But stock internals have proven to hold 12psi daily for years, so 7-10 is a little low. The beginner setup uses 370cc injectors from an SR and the stock KA MAF, and can get you to ~250rwhp.
For more, SEARCH.
Later - Brian
