Do I win the award?
for you.... you might want to reset the MPG counter in the options. it may or may not make a difference. if your driving habits are better then the previous owner then the MPG should go be better than what you have now...TOMatBMR wrote:My display has consistently shown 16.6 since I bought the car. I was hoping to get around 20 but no luck.
I will check that out, thank you!IlyaKol wrote:Here is a thread for some other suggestions that can help improve gas mileage:
gas-mpg-s-what-can-we-do-t529082.html
Yeah I reset it and still end up at the same.BizAsUz wrote:for you.... you might want to reset the MPG counter in the options. it may or may not make a difference. if your driving habits are better then the previous owner then the MPG should go be better than what you have now...TOMatBMR wrote:My display has consistently shown 16.6 since I bought the car. I was hoping to get around 20 but no luck.
also I assume that if you are using premium octane gas that helps with fuel economy.
Here's a pic I just took now that my tank has gone empty. The needle looks like it's at an 1/8th of a tank because I'm taking it from the left angle but it's really nearly touching the E line.IlyaKol wrote:What is the manually calculated MPG (number of gallons filled/number of miles driven)?
Regarding your last bit...you DO get worse MPG's with winter gas. That's a known side effect of the 'winter mix'. I usually get 17-18 during the winter and 19-20 in the summer. It's been that way on all my cars since I started driving...97 Maxima, 99 Maxima, 07 M, 11 M, etc.The00Dustin wrote:Ilyakol's method gives you the average MPG for a tank and will only be off by the difference in how full the tank got between the two fillups (minor differences due to angle of the ground, temperature inside the tank at fillup, etc). The computer is trying to calculate the average MPG for whatever you tell it, but it can't measure the gallons that precisely, so it uses other factors out of necessity, not because it's a better method. It's higher if you reset it when you're driving because getting up to speed wasn't factored in. In other words, if you reset the average when the car is off and fill up the tank, the division trick should give you the same number as the number on the screen, but the computers don't always get it right. Some are always high, some are always low, and some start out right but end up wrong. Mine was right following that procedure for the first few years after I bought my M, but in the last few years, it is always ~1 MPG high with summer gas and ~1 MPG low with winter gas. Presumably something could be repaired or replaced to get it back to accurate, but I don't know what.
I know that, but what I meant is this:IlyaKol wrote:Regarding your last bit...you DO get worse MPG's with winter gas. That's a known side effect of the 'winter mix'. I usually get 17-18 during the winter and 19-20 in the summer. It's been that way on all my cars since I started driving...97 Maxima, 99 Maxima, 07 M, 11 M, etc.
I did a trip from San Jose to OC on a full tank with little less than a quarter to spare, avg 27 miles a gallon, I got 400 miles before I filled up.bakili wrote:Reviving a summer thred now. So I might be beating everyone at "The worst gas miliage" award. Max I'm getting is 13.4 driving like an old lady with bad vision, mostly local city driving and very little highway. I just bought the car (with 89K miles) 1 month ago and I love it regardless. What I did to it is:
1.Megan Axle backs / 2. Z-tube / 3. K&N drop in filter / 4. Changed all sparkplug to platinum laser OEM .44 gap / 5. Oil changed to Royal purple with Wix filter / 6. Brand new Kumho ecsta LX platinum (19" sport wheels)
I did reset MPG counter in M35 system, couple of times took batter out for few minutes to clear all info. The very first time filled up Chevron Techron, now using Shell premium. Any ideas guys why I'm getting such lousy gas miliage?
p.s. planning on taking a trip from SF to LA this X-mas, so curiour how that will work out.
