pgt892 »
https://forums.nicoclub.com/pgt892-u2513.html
Mon Apr 25, 2005 2:30 pm
The owner of takamotorsports posted something on Zilvia I think, that went like this: "First off, If anyone ever has any problems, all you have to do is email me. I’m always more than happy to help anyone out till their lines are perfect since so many setups can differ from person to person.
Just to clarify: The two larger lines are the water/coolant lines with 14mm ends. The smaller line is the oil inlet line. The oil inlet has a blue fitting (12mm) which goes to the block and silver fitting (11mm \ 7/16) on the other side, which is the turbo side. That is the standard GT turbo fittings sizes for T25, T28, GT25r, and GT30R. The problem is individual fitment in where the 90’s and straights fittings need to be for EACH person. IF someone needs to have a line with different fittings or different bends, all you have to do is let me know, and I always make sure in the end you will have what you need to make it work, otherwise what’s the point? -harp"
