Does anybody know how to disable the beep?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Athikerguy4life
Car: 2008 Nissan Versa
Just wondering if anybody knew how to disable the beep that starts going off every time you have the key in and the door open. Often times I play the stereo with the doors open and the key in (obviously) and the beep is rather annoying... If its as simple as cutting a wire or removing a little buzzer deal I would be incredibly excited. Even just finding the spot it comes from and hitting it with a hammer. I already have the lock/unlock chirp turned off, so im not talking about that. just the little beep beep beep that goes off when you open the doors.
SnipeMeNot
isnt that the beep when you put the key in the ignition without wearing the seatbelt?
Aaron_versa2012
Car: 2012 Versa SV Sedan
MTX 6.5" speakers
Pioneer AVIC-x930BT
JBL GT1000D
Alpine Mono Block
isnt that so you know its draining your battery. Didn't that happen on breaking bad and they were stranded in the desert. I just roll the windows down. or play my amp in the garage.
Return to “Versa Technical Discussions”
