neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Mon Sep 11, 2006 1:45 am
Like I tried to tell you man, they tune your ecu for mods, not your engine with the mods on it. You need to understand that pdm worked on maybe 5 really good engines(great shape) and probably averaged the results, so if your car is in worse shape it will be lower hp#. Your trans might be worn out more or even your rearend could have lost some power, not as much as you lost but some. All engines are unique,as in the guy who owned the car before, doing or not doing his oil and plugs and wires. Is your car up to date with its tune up and oil change. Is your maf dirty? What I'm getting at is the car should be in decent shape before mods. Comp. test? Even little sensors are so important, like coolant temp(not dash temp) sens. Did the dyno use a wideband to monitor your air/fuel ratio?, if so post that so we can see if its in the power ratio.
