Does anybody have any info on the Kinetix Intake manifold!?!?!
rb26dett1989
Car: Nissan Altima SE R
Is it worth $850? Were there any noticeable gains?
gucio69
Car: 2008 Nissan Altima Coupe 2.5S 6MT
From what I understand intake manifolds are more beneficial if you have forced indution. On an engine without a turbo you might be good for something in the neigborhood of 10 hp at the most. I'm sure someone with more experience with this will chime in soon with more info.
marvin5087
Car: nissan altima coupe 08
yep..not too much of a gain..some even say there has been some power loss..i would def love to upgrade to that particular intake manifold but they run so much like 800-900..IF i had the money, but then again my exhaust cost about the same and didnt give me the same performance the intake manifold would have
bina12834
Car: 06 G35 coupe
wow.....dont spend that much on an intake.....a $150 Fujita will give you the same power gains as that thing. The only difference between intakes is the noise it makes.
jungleboogie
Car: '08 VQ35DE Sedan -- Winter Frost w/ Black Leather
bina12834 wrote:wow.....dont spend that much on an intake.....a $150 Fujita will give you the same power gains as that thing. The only difference between intakes is the noise it makes.
wait, what?
an intake manifold is used to evenly distribute incoming air into each respective cylinder... helps to increase efficiency and also increase performance
