1badsleeperhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Does any one know how to do the Lazy Eye conversion?Sun Oct 17, 2004 8:32 am
Postby
1badsleeper »
https://forums.nicoclub.com/1badsleeper-u20852.htmlSun Oct 17, 2004 8:32 am
I know there are a few diffrent ways, You can turn the seliniods up to make the light come up, and there is an actual part you can buy that does it, and there is some way to do it with the wiring in one of the swithces, any info would be helpful.
Postby
1badsleeper »
https://forums.nicoclub.com/1badsleeper-u20852.htmlSun Oct 17, 2004 1:04 pm
the light brown wire did not work, now they just dont open when i hit the switch, so i had to sodder it back together, any ideas why it didnt or if the wires are diffrent in the 89?
Postby
[Zero-S] »
https://forums.nicoclub.com/-u-u6575.htmlSun Oct 17, 2004 1:42 pm
When the switch is in, they will not open. Make sure the switch is off, turn the lights on, then turn them off and tap the switch rapidly until the lights are at the intended position. It works, I have it done.
