does any one have maps
slw240sx
Car: 1990 Ca18det 240sx Hatch
ok any one who has maps for the CA ECU please email them to me. im looking mainly for maps that have only been modified for boost cut and bigger MAF, and bigger injectors if it has them, i got a formula to figure that out already, but i need to know how to map out the boost cut and ideas?
paul_s13
Change the TP limit to 255 on all of them to get rid of the fuel cut, I do have maps for afms/injectors but my business partner won't be happy if I sent them out for free, sorry
slw240sx
thanks paul ! what type of deal can we cut for some premapped stuff ?
CA19DET
i got them
### NISSAN S13/RS13 CA18DET MAP ADDRESS (E)## Variable,Start-Address,X,Y,Map size,value,Map-name
#UNIT NAMETYPE_UNIT,S13/RS13(CA18DET),*,*,*
#HIGH/LOW octane Fuel map.HIGH_FUEL,&H3D00,16,16,256,1,High octane Fuel mapREG_FUEL,&H3700,16,16,256,1,Low octane Fuel map
#HIGH/LOW octane Ignition time map.HIGH_FIRE,&H3C00,16,16,256,1,High octane Ignition timeREG_FIRE,&H3A00,16,16,256,1,Low octane Ignition time
#K required numberK_DATA,&H3F80,2,1,2,1,K required number
#Void blast-off timeIGN_TIME,&H3F8F,1,1,1,1,Void blast-off time
#VQ mapVQ_MAP,&H3E18,16,1,104,1,VQ map
#Fuel/Ignition time TP scaleTP_SCALE_FUEL,&H3BC0,16,1,16,1,TP scale (Fuel)TP_SCALE_FIRE,&H3BE0,16,1,16,1,TP scale (Ignition time)
#Fuel/Ignition time RPM scaleRPM_SCALE_FUEL,&H3BD0,16,1,16,50,RPM scale (Fuel)RPM_SCALE_FIRE,&H3BF0,16,1,16,50,RPM scale (Ignition time)
#TTP MAX/MINTTP_MAX,&H3F40,16,1,16,1,TTP MAX
#TP LimitAF_LIMIT,&H3690,16,1,16,1,TP Limit
#Acceleration increase volumeADD_FUEL,&H3970,8,1,8,1,Acceleration increase volume
#Rev.LimitREV1_LIMIT,&H3980,1,1,1,50,Rev. Limit 1REV2_LIMIT,&H3981,1,1,1,50,Rev. Limit 2REV3_LIMIT,&H3982,1,1,1,50,Rev. Limit 3REV4_LIMIT,&H3983,1,1,1,50,Rev. Limit 4
#Speed LimitSPEED1_LIMIT,&H392C,2,1,1,2,Speed Limit 1
#Add.map 1ADD_MAP1,&H3990,16,1,16,1,Variable air close
#Add.map 2ADD_MAP2,&H39A0,16,1,16,1,Variable air open
i have some .adr files i got wwhen i was fiddleing around with eprom tuner ideas..
emial me and i'll send them to you.
also check - http://tuning.silviansw.com/th....html
Xero
they can be found here, along with a nifty ROM tuner software
http://www.boostcruising.com/silvia/eprom.asp
rtsol
but those are stock. i have Mine's, SWAT, and several custom tunes, but im not allowed to disclose them at this time. sorry.
