Veriest1 »
https://forums.nicoclub.com/veriest1-u15441.html
Sat Feb 12, 2005 10:55 am
Well, if you have a 95 240 with the KA24DE motor then you can use the KA24E pistons to achieve low cost high compression. They will give you about 11.1:1 or something very close to that. With the low cost of these, like from someone doing an SR swap, changing the pistons later on for turbo applications won't be such a strain on the wallet.
Also, I think PDM/Colt cams and possibly JWT off-the-shelf cams(Read: not custom grind) are the same for turbo and NA applications. Requiring only a change in timing if you switch induction styles. Search around on cams and check their sites out and even call them to ask questions. Don't just take my word for it.
I hope that helped at least a little bit.
