Does an E1 Crank shaft need to be rehardened after grinding 0.040"
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
63 320
Car: 1963 Datsun 320 pickup
my dad had one of these in the 80's and was told after the bearings failed that the reason was the crank was not hardened after grinding.
does anyone know if the crank needs hardening after machining? mine was just done 0.040 under.
I do not believe so - we're talking a 60-hp low-rpm motor.
Here's some good info from another source - with the takeaway being, knowing how the crank was originally manufactured would help.
"Most stock OEM steel crankshafts have been induction hardened. This is a low cost process in which the surface is heated by a high frequency alternating magnetic field that generates heat in the crank's surface quickly before being quenched. The depth of this hardening process is around .060 - .080. Because of uneven heating and cooling, this crankshaft hardening process creates stress within the crankshaft. While it is an ideal hardening process for stock applications, it is less then favorable for high performance racing applications.
Tuftriding was a process used by some OEM's on special high-performance crankshafts, primarily to avoid the stresses imposed by induction hardening. In Tuftriding, the crankshaft is immersed in hot cyanide compounds, creating a tough, resistant surface that improves fatigue resistance. The hard layer in a Tuftrided crank is usually very shallow, only penetrating around .005. One drawback of Tuftriding is the potential for warpage of the crank.
Nitriding is a chemical hardening process in which the part is heated in a furnace, the oxygen is vacuumed out, and nitrogen is introduced which penetrates the entire surface. The depth of hardness is dependent upon the time the crankshaft is exposed to the gas. Typically, a nitrided crankshaft will have a hardness depth of about .010 - .030. Nitriding is a low heat process compared to Tuftriding, but it shares the advantage of avoiding the introduction of localized stress zones as in induction hardening.
In most cases, a stock OEM steel forged crankshaft can be welded and/or ground then installed without concern. The induction hardening process has a significant depth, and on non welded journals will remain after being ground.
Tuftrided crankshafts can be welded and ground without concern. However, the shallow depth of the hardness would be lost after the grind. Therefore, it is recommended to have the crankshaft hardened again.
Nitrided crankshafts can easily be welded and ground without concern. A .010 undersize grind will cause some of the benefits of nitriding to be lost. At .030+ undersize, nearly all of the nitriding benefits are lost. Therefore, it is recommended to have the crankshaft hardened again after grinding.
It is important to discuss crankshaft hardening with the machinist which will be grinding your crankshaft prior to the weld and/or grind. These hardening processes can add to the size of the journals, so the crankshaft needs to be finish ground in such a way that allows for the expansion caused by hardening. I have personally ground new aftermarket crankshafts that were shipped out of tolerance. Trust me, as a machinist it is time consuming to setup and grind off .001 of an inch. So please let your local machinist know if you plan to have the crankshaft hardened!
There are some automotive machine shops that will not weld a steel crankshaft because it has been hardened. As a machinist, I have never turned away a crankshaft weld because of hardening. If you note my explanation of the hardening processes above, hardening is generally restricted to the surface. To weld a tuftrided or nitrided crankshaft, the journal or thrust needs to be underground first to remove this surface hardening. Then the weld can be applied. In cases where induction hardened crankshafts have been severely damaged, normally pre-grinding the crankshaft for a weld removes this hardening.
During the machining process, cast iron crankshafts become work hardened. If a more durable crankshaft is desirable for your application, it would be a good idea to look into purchasing an aftermarket steel crankshaft.
63 320
thanks for the reply, I saw that article and i hope that is true of mine, I was hoping someone may have had a crank ground recently with good results just for peace of mind
Return to “Datsun 320”
