Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Apr 28, 2008 2:21 am
What happens when you skip a component/hose or two in the so called total restoration.............oem parts alone would run $2,200 to do a total restoration.
Hopefully just a bad o-ring leak.Watch out for hot/cold mix door failing in hot position common on 94-96 after a winter season.
