does a VG30 crank and conrod fit into VQ30?
Discuss topics related to the VQ series engine.
kahren
i was wondering if this was true, i remember reading somwhere a while back that if you take out the crank and rods from a 300zx VG30 and fit them into the VQ30 it will become a 3.4 liter. i was wondering if anyone of you could confirm this, or if u have the 2 cranks layign around and could measure this.
sil80drifter
Car: 1990 240SX Hatch
this is very interesting, can someone confirm or oppose this? it sounds like something nissan may have done to make the "new" 3.5 liter VQ...
sil80
Q45tech
Everything in the 3.5 is new, totally different design.........light duty knifed crank and rods. Floating cylinder liners, low ring tension.......light pistons and wrist pins.
They attacked the HP poblem differently by reducing reciprocating weight and lowering residual friction [narrow bearings], bucket lifters.
sil80drifter
Ok, but what about the above rumor? It is common knowledge that there are quite a few parts across nissan engines that can be cross swapped, etc, what about these?
sil80
s13sr20chris
not all vg30s are created equal. im not sure what size crank the z32 motors had but the sohc vg30s had a small crank in the older ones and a larger crank in the newer ones. this was to solve a prob with cranks snapping off after slappy at the lube and tune overtightened the belts.
PalmerWMD
Car: 2004 350Z
So Dennis are you saying the VQ35 has "weaker" bearings than the VQ30?
Fred....:)
sil80drifter
let's not get off topic. this is kind of important. does anyone have sound data regarding the question?
sil80
Q45tech
Measure them! When you have a lighter crank [and lighter balance weights] because you have lighter rods and wrist pins you can use narrower bearings to reduce the friction.
Back in 80's and 90's many engines were over designed to extend the life............250,000-300,000 miles later engineers saw where they could reduce costs without affecting the requirements for at least 100,000 mile life..........many of these cost saving designs had the effect of increasing power and torque by reducing friction from oil whipping [knife edging balance weight portion].
Study section EM ---- pages 119-125 in your G35 FSM.
http://www.intermet.com/resour...5.pdfh ... Ne...19276
sil80drifter
I don't have either. But maybe someone else does.
sil80
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
