Carter »
https://forums.nicoclub.com/carter-u8551.html
Mon Jul 14, 2003 7:21 am
A rear anti-roll bar (more accurately describes what it does) helps reduce understeer. That is, the car turns better with slightly less steering input. After installing a rear bar, the driver will notice this, thus the "improved handling". Going too stiff makes the car "twitchy" and it tries to swap ends at turn-in, thus the need for a balanced car. On the track, we start the weekend with the adjustable rear bar on full soft. Each session, we stiffen it one setting until the car turns-in nicely but is still fairly stable. This balanced handling makes the car easier to drive quickly and brings down lap times.
Installing stiffer rear springs (obviously more involved) and even raising rear tire pressures, to a point, can give the same effect.
Stiffening the front bar, springs, and tires increases understeer. Stable and easy to recover, but slow.
Easy to remember, "the stiffer end of the car loses traction first." With a balanced car, the car turns-in nicely, and the driver can get on the throttle early at corner exit. With an oversteering car, the driver is fighting the car to keep it from spinning and has to wait to get it stable, to pick up the throttle. With an understeering car, the front end washes out and the car won't turn. The driver has to slow down to get the car to turn, he waits to get through the corner, and then gets on the throttle.
Carter
