a_ahmed »
https://forums.nicoclub.com/a-ahmed-u40386.html
Thu Apr 05, 2007 11:39 am
Well, I've been considering different things to do to the front end, to make it more aerodynamic and at the same time generating more downforce but less drag.
So take the s13 into account, the popups when up suck, when down, well.. the nose is relatively low, more so than fixed upwards headlight cars.
Put on the s13 silvia front end, what do you get? Nothing much lower, however the front end is shorter in effect slightly.
Put on the s15 front end, what do you get? Slightly more bulged, relatively the same length as popups, but much more bulged and wider.
I want to get rid of popups for weight reasons, however when down the car should not have as much drag. If I do a s15 conversion I'll definetely lose weight but the front end should have more drag no?
A nice functional front wing/lip would be able to increase downforce... in any case though.
So in contrast, an s13 with popups down and an s13 silvia, they are relatively same nose dive, however the silvia is shorter. The question is, does the front being longer mean more aerodynamic or less aerodynamic?
