Does a B15 transmission bolt up to a SR20det?
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
nismo-man2
Car: RPS13
I heard a rumor that the B15 6spd bolts up to a sr20det. Is this true, if so what clutch would you use?
nametakennow
Car: '06 MINI Cooper S
The B15 5spd VLSD transmission from the 00-01 Sentra SE does without a problem. It's stronger than B13/14 ones. They all use the same clutch.
The 6spd from the Spec V requires some significant modification to bolt up. I think you'd use a stock Spec clutch.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
