~Does a 45 series tire eliminate contact distrotion if running a 235 tire on a 17x7?~
gotime242
Car: Mr2 Superduty
I know this sound like the hypothesis from an 8th grade science project, but im losing my mind over trying to decide what size tire i am going to run on the rear of my mr2 with 17x7's all the way around.
I hear a lot of people saying that 235/40's work well on 17x7's. But others say that this will have a distorted contact path. I also know that by going up in sidewall, you can go out in width a little bit. So would running a 45 series tire (235/45) work well, and eliminate this distortion if used on a 17x7? What do you guys think? Also does anyone have any close-up pictures of the sidewall of a 235 on a 17x7?
Thanks a lot!
-Dylan Shine / gotime242
-91 Mr2 turbo
Exar-Kun
Car: 2005 350Z
.............step 1- search.step 2- search again, we just discussed 17x7" tire options.
step 3- read this:
summary of the discussion: nothing over a 225-45-17 is really a "good fit", an optimal tire would be a 215-45/40 or such tire. anything wider will be sequeezed severely on the wheel, esspecially a 235-40.
just because you can physically mount it on the rim, doesnt mean you should.
-chet
SHiFT
Exar-Kun wrote:.............step 1- search.step 2- search again, we just discussed 17x7" tire options.
step 3- read this:
-chet
Step 1- I did search.
Step 2- I searched a little more, and more, on about 3 different forums.
Step 3- Thank you for NOT answering my question, as no one else has yet in my searches. I am not asking about a 235 with a 40 series on a 17x7. I am asking about a 45 series sidewall. This has not been discussed, it has been either 225/45 or 235/40's, NOT 235/45's. It is a known fact that a tire with more sidewall can be run in a larger width, which is why i ask if a 235/45 would eliminate the contact distortion.
And yes i know you can physically mount a big tire on a small rim. I know i could mount a 255 if i wanted to. But im just trying to find out how far you can go with not only width, but in sidewall in consideration as well.
SHiFT
Oh, and this is gotime242 by the way. I just forgot to sign out on this screen name, and sign in on gotime.
Exar-Kun
Car: 2005 350Z
see, but I did answer your question, and it was answered in a thread called "17" wheel and tire help please" that you can probably locate since its recently active. and we DID discuss a 235-45-17, and my statement DID tell you a 235 is too wide, even in a 45 series.
in fact, I know i've discussed reccomended sizing on a 7" wheel, up to and including 245-45-17, 235-45 and others.
thanks for your time.-chet
edit: also, search does not appear to work correctly since the server change. :/ sorry I was so critical, but I did cover that topic in the thread mentioned.
SHiFT
Thanks! I decided just not to push it. A kumho Mx will be mighty sticky anyway. I talked to tirerack ppl as well, and did a little more research. Im over it though, its all good. Just cant wait to get the new 225/45's!! They will be gods among mortals!!
(Im just sick of the 205/40's i currently have, and am exited about getting new tires) :)
Later!
