Do you know what these white spots on the driveway are?
Freeze Time
Car: 1998 Infiniti QX4
I got some kind of power cleaner you mix with water from my mechanic that was supposed to clean up power steering fluid stains on my driveway(which didn't work, he says I used too much water)and these white things popped in places the fluid didn't spill. I googled it and can't find an answer. Does anyone know what they are and how to get rid of them? And no, it's not bird poop.
wmj259
Car: 2002 Nissan Pathfinder
You could try some Concrete floor cleaner. Homedepot should have that or Walmart for a less aggressive cheaper alternative.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Probably will need a pressure washer to remove the spots.
Freeze Time
They just appeared today though. How did this soap unearth these spots? What are they?
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
What was the power cleaner that was used? Is it possible it's just old white paint that had grimed up over time and the cleaner exposed them?
MisterH
Car: 1999 Infiniti QX4
I've had perfectly acceptable results using a very old technique: pour kitty litter on oil stains; let it sit overnight to fully absorb and then sweep it up the next morning.
Freeze Time
No paint stains. Power steering fluid has had ground up kitty litter on it for 5 days now. I checked a spot earlier and the stain is still there.
