do you have to drop the fuel tank to change fuel lines?
CagedVert
Car: 240sx convertible w/ Ka-T
im having a leak from one of my hoses coming from my fuel pump lid. i was looking at it and i dont really see a way to change them without dropping the tank. anyone know the easiest way to do change them? any help will be appreciated!
biggie
In the trunk you should have the access port to the fuel pump.
CagedVert
i do but im trying to change the 2 rubber lines that go to the lid of the fuel pump access lid, they seem impossible to change without dropping the tank
biggie
That might be true. Might be possible to just loosen the straps and slightly drop it instead of completely removing it.
onosqv
Car: '92 240sx Vert
I've done it before, it's not impossible, just takes some patience. It's been several years, but the general steps as I remember them:
1) Put the car on jack stands
2) Remove the fuel tank/pump cover
3) Loosen the clamps & spray area liberally w/ WD-40/Liquid Wrench/similar
4) From here, a plier/clamping wrench of some sort & large needle nose pliers should help you loosen the hose - first get it to move left & right, then push it out.
5) From under the car, you can get to the other side of the rubber hose - may be easier w/ the passenger tire removed
I was able to do it w/ just that. However, if the hoses are REALLY on there, you can always cut them off w/ a razor blade since you are replacing them anyway. Of course, I'd look through from under the car to see if you can get to everything first.
