kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Fri Jun 04, 2010 1:54 pm
For towing I'd use it prior to taking off from a stand still to prevent the CVT from "upshifting" too soon. By keeping a lower gear ratio you place less stress on the CVT components and also keep the engine rpms higher for better torque as well.
I wouldn't advise using the OD off button for normal around town "downshifting" to slow down rather than just using your brakes, it already has built-in programming that I find to be very active, if you start coasting down a hill, even a moderate slope, it kicks right in and slows the acceleration. I can't say if using the OD off button on the fly as you drive around town would place more stress on the CVT for sure, but I'd rather error on the side of caution here. The CVT and computer that controls it is very sophisticated and always making adjustments, so I'd prefer to let it do it's work rather than interfering - I find when you hit the OD off button when travelling at speed it seems to be a bit of quick downshift rather than a more gradual process. It just doesn't feel real smooth.
And most importantly, a new CVT costs upwards of $4 to $5 thousand dollars, a full brake job should only be necessary every 60 thousand-ish miles depending on driving style (for me this will be every 7 or 8 years) and is quite a low priced maintenance item if it's just pad replacement, normally $100 bucks for the pads and an hour or two of labour. So I'll take the $200 brake job over the $5000 CVT replacement any day and error on the side of caution!
