Do you guys have the same noise on your RPM gauge?
andgen
Car: Nissan Rogue 2011
http://www.youtube.com/watch?v=d8XWS1Np ... AAAAAAAAAA
We tested several rogue. They all have same moise, but the new ones don't. That means it could be worse in the future. :gotme
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Hi there, that ticking noise does not sound normal; just to be clear, are you thinking the noise is coming from the gauge itself as your thread topic implies? It's very difficult to tell from the video clip where the sound might be coming from. Have you listened for the noise from outside of the vehicle?
TaiLuu
Car: 2009 Nissan Murano LE AWD
2011 Nissan Rogue SV AWD
2014 Nissan Pathfinder Platinum
Pull the fuse for the cluster and then rev the engine. See what happens.
andgen
kerrton wrote:Hi there, that ticking noise does not sound normal; just to be clear, are you thinking the noise is coming from the gauge itself as your thread topic implies? It's very difficult to tell from the video clip where the sound might be coming from. Have you listened for the noise from outside of the vehicle?
I brought my rogue to the dealer. They tested it and compared it with the other rogues. Nearly every used rogue has the same noise. Some are even louder. Then they got the conclusion that the noise is coming from the gauges. Unless nissan recall the gauges, they won't repair it. :frown:
Do you guys has the same noise on your rogues? :confused:
Chevvie41
Car: 2011 Nissan Rogue SV
I've been lurking on these forums for a year now, ever since I purchased my 2011 Rogue SV 15 months ago. I decided to register for an account in order to chime in on this topic.
I have the EXACT same noise on my Rogue, and it seems to be coming from the RPM gauge. It seems to be the most noticeable at around 1500 RPM. I hear it all the time, even when the sound system is on at a low volume. I might be delusional, but it seems to be louder a colder temperatures.
I still need to take my Rogue to the dealer for NHTSA Recall 11V-565 (electronic power steering unit), so maybe I'll ask what their thoughts are regarding this ticking/clicking sound.
kerrton
This is a strange issue, my 2008 SL FWD has no such noise and I can't imagine any vehicle experiencing this as a "normal" as-designed noise. Please report back after you've had your vehicle looked at by your dealer. This looks to be a problem only with later model Rogue's and it's obviously something that should be corrected.
TaiLuu
I just now tested the issue a few secs. Ago.
The issue is the end of the needle is scraping the cluster When it touches 1000 rpm.
Seems like Nissan rushed the cluster design.
pawprint
Car: 2012 Nissan Altima 2.5 SL w/technology package
My 2010 started squeaking around the gauges also. It would squeak while diving on any road surface that wasn't mirror smooth. Finally I shoved a tube sock around them and wedged it in the cracks. That finally shut it up. :woot:
Return to “Rogue Forum”
