graphikg04 wrote:Hey man, first of all, I do not think you should ever even down shift into first. You shouldnt even need to downshift into first, it unneccesary. And double clutching is not important either, to down shift the best way, you should learn how to heel-toe. Double clutching is also uneccessary. And actually, I think that in the cold mornings, 2nd gear does grind. What I do is just shift into it slowly. But I always try to warm up my car first and leave it running for a bit, and when it is warm it doesnt grind at all. Try that. PEACE
graphikG
apzak wrote:huh?
What I do to get into first is disengage the clutch.. shift to N... gas to 2-3k rpm.. disengage the clutch.. shift to 1st.. that's double clutching right? Then what's heal to toe?
Bubba1 wrote:...There was also a large thread on this very subject a few weeks ago.
SWIFT_DRIFT wrote:heel-toe is double clutching while breaking into corners and such. the first step to learn heel-toe is to learn proper double clutching techniques.
also i have never read this is better for your transmission?
all i know is its a completely smooth downshift with no clutch grab and when done properly and fast, its like having your own sequential transmission with a clutch of course.
SWIFT_DRIFT wrote:i can heel-toe with no problem in my old s13 and my s14, and i wear size 11 shoes. some people just cant tweak their foot like that.
c-kwik me and you always get in a little debate over this topic, even on the other threads lolC-Kwik wrote:Heel-toe downshifting is not double-clutching. They are two different things, but can be used with each other. I heel-toe on a regular basis but never double-clutch.
It is not necessarily better for your transmission. Only your syncros. But as I've always said, why have syncros if you are not going to use them? What are you saving them for? For the next owner?
And rev-match downshift is only as good as the rev-match downshift is performed. But rev-matching is not double-clutching. Like heel-toe, rev-matching can be done with a double-clutch shift. I can't think of any situation where you would rev-match without braking though, since on a race cource, you are generally either accelrating as fast as you can, turning as hard as you can and braking as hard as you can. There is some transition,, but you want to maximize the use of all available traction. That will give you the best lap times. So you will generally be downshifting only during your braking(heel-toe).
BTW, a lot of this was dicussed in a previous thread. Here it is:
http://www.nissaninfiniticlub....=9776
dubbs wrote:hey i have a 91 240.. 118k miles on it.
i just got a new clutch 10 days ago.. and when i shift into second now it grinds when its cold
its weird before the new clutch it never did that.. and i think my brand new clutch is slipping a little bit.. when im in 3rd or 4th and above 3k.. it sometimes slips.. i jus went above 3k 3-4 times yesterday because i didnt want to do it after a week or so.
i have to bring it back to the transmission shop, and ill tell them about it have em check it out..
