do you disconnect breakline during coilover install?
xagna
I am wondering if it is a must to disconnect breakline during coilover install on s13?
If I have to disconnect the breakline for installing a coilover, do I have to drain break fluid?
Red coupe
Car: 92 Nissan 240sx Coupe
no need to disconect the line, just undo the clip that holds it to the strut(it has a lip so that you can pop it off with a screwdrive or soemthing) if you do for some reason undo the line you will need to bleed the brakes afterwards, you shouldnt need to drain the fluid but you will want to cover the ends with something(anything with lint including papertowls etc...=bad).
Modified by Red coupe at 8:41 PM 5/25/2005
xagna
Thanks!
